770
Change PaneTabItem Width and Height depending on PaneLocation ?
We developed an application using XamDockManager and 3 content panes, intially docked on the left.
Free Web Proxy
The panes can also be docked at top or bottom, and the header is then displayed horizontally. That works fine.
Free Web Proxy
In order to standardize height and width between panes, we used a resource in the xaml code (targetting PaneTabItem) :
<ptr:MyForm.Resources>
<Style TargetType="{x:Type igDock:PaneTabItem}">
<Setter Property="Background" Value="White"/>
<Setter Property="Width" Value="25px"></Setter>
<Setter Property="Height" Value="120px"></Setter>
<Setter Property="HorizontalAlignment" Value="Left"></Setter>
<Setter Property="VerticalAlignment" Value="Center"></Setter>
</Style>
</ptr:MyForm.Resources>
Il looks good when docked on the left, but docked on top or bottom it's awful : height and width are still the same (which seems normal by the way).
Free Web Proxy
I tried Style triggers to detect the pane location (and invert width and height on the fly) : didn't work. (wrong syntax ? Wrong objects used ?)
<Style.Triggers>
<Trigger Property="igDock:XamDockManager.PaneLocation" Value="DockedLeft">
</Trigger>
<Trigger Property="igDock:XamDockManager.PaneLocation" Value="DockedRight">
</Trigger>
<Trigger Property="igDock:XamDockManager.PaneLocation" Value="DockedTop">
<Setter Property="Width" Value="120px"></Setter>
<Setter Property="Height" Value="25px"></Setter>
</Trigger>
<Trigger Property="igDock:XamDockManager.PaneLocation" Value="DockedBottom">
</Trigger>
</Style.Triggers>
</Style>
I tried to catch PaneDragEnded event on the code behind, and change height and widtdh : I didn't manage to reach the PaneTabItem  of the ContentPane that is currently dragging. ContentPane doesn't have a direct link to "his" PaneTabItem, and although PaneTabItem has a "Pane" property, I don't see where all PaneTabItems could be listed for the DockManager...
Is there a way to achieve what I want to do ?
Many Thanks in advance,
Thomas
