Could anyone help how to add the Stacked area series dynamically?
following code sample will create 3 stacked area series. I need to append additional series in button click event.
Could any one help?
xaml:
<Window x:Class="InfragisticStackedChart.MainWindow" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:ig="clr-namespace:Infragistics.Controls.Charts;assembly=InfragisticsWPF4.Controls.Charts.XamDataChart.v11.2" Title="MainWindow" Height="350" Width="525" Loaded="MainWindow_OnLoaded"> <Grid> <Grid.RowDefinitions> <RowDefinition/> <RowDefinition/> </Grid.RowDefinitions> <ig:XamDataChart Grid.Row="1" x:Name="theChart" Legend="{Binding ElementName=xmLegend}" /> <ig:Legend Grid.Row="0" x:Name="xmLegend" Background="White" Orientation="Horizontal" /> </Grid> </Window>
Code:
namespace InfragisticStackedChart { using System.Collections.ObjectModel; using Infragistics; using Infragistics.Controls.Charts; /// <summary> /// Interaction logic for MainWindow.xaml /// </summary> public partial class MainWindow : Window { public MainWindow() { InitializeComponent(); } private void MainWindow_OnLoaded(object sender, RoutedEventArgs e) { GroupBy gb = new GroupBy(); gb.GroupMemberPath = "Date"; gb.KeyMemberPath = "Installation"; gb.ValueMemberPath = "Emission"; ObservableCollection<InstalationEmissionDateInformation> temp = TestEmissionsCollection.GetItemSource(); gb.ItemsSource = temp; Infragistics.Controls.Charts.NumericYAxis yAxis = new NumericYAxis(); CategoryXAxis xAxis = new CategoryXAxis(); xAxis.ItemsSource = gb; // xAxis.Label = Resources["labels"] as DataTemplate; xAxis.Label = "{Key}"; this.theChart.Axes.Add(xAxis); this.theChart.Axes.Add(yAxis); StackedAreaSeries series = new StackedAreaSeries(); series.XAxis = xAxis; series.YAxis = yAxis; series.ItemsSource = gb; series.AutoGenerateSeries = true; theChart.Series.Add(series); } } public class TestEmissionsCollection { public static ObservableCollection<InstalationEmissionDateInformation> GetItemSource() { ObservableCollection<InstalationEmissionDateInformation> retVal = new ObservableCollection<InstalationEmissionDateInformation>(); retVal.Add(new InstalationEmissionDateInformation("A", 5, "1/1/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("B", 2, "1/1/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("C", 7, "1/1/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("A", 6, "1/2/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("B", 3, "1/2/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("C", 8, "1/2/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("A", 6, "1/3/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("B", 3, "1/3/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("C", 6, "1/3/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("A", 4, "1/4/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("B", 3, "1/4/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("C", 7, "1/4/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("D", 7, "1/1/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("D", 8, "1/2/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("D", 6, "1/3/2012", 1)); retVal.Add(new InstalationEmissionDateInformation("D", 7, "1/4/2012", 1)); //retVal.Add(new InstalationEmissionDateInformation("D", 9, "1/1/2012", 1)); //retVal.Add(new InstalationEmissionDateInformation("D", 3, "1/2/2012", 1)); //retVal.Add(new InstalationEmissionDateInformation("D", 6, "1/4/2012", 1)); return retVal; } public TestEmissionsCollection() { } } public class InstalationEmissionDateInformation { public string Installation { get; set; } public Decimal Emission { get; set; } public string Date { get; set; } public Decimal Assignation { get; set; } public InstalationEmissionDateInformation( string installation, Decimal emission, string date, Decimal assignation) { Installation = installation; Emission = emission; Date = date; Assignation = assignation; } } }
Hello John,
Thanks again.
That helps. Thanks
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thank you for your post. I have been looking into it and I created a sample project for you using your code with a little modification. Basically I added a Button and handled its Click event. In the handler I added items to the collection that is set as ItemsSource and since it is an ObservableCollection and implements INotifyCollectionChanged interface, the newly added items are added to the XamDataChart. Please let me know if this helps you or you need further assistance on this matter.
