180
Wrong size of visuals & lost Labels (xamDataChart) while using WPF Reporting Engine
Hey,
I have two problems while using the WPF Reporting Engine from infragisitcs.
First problem is the wrong size of visuals, that has not been displayed before in the application.
For Example:
A TabControl contains three TabItems. Each TabItem contain one XamDataChart and one XamRadialGauge contained in a grid. When I start the Application the default view is the first TabItem. Then I can either export or get a preview of the three TabItems (grids).
Result: Only the first section have the correct size of visual (because this is the default view).
Workaround for the user: Each TabItems must be activated an displayed on the screen before printing / exporting the view to get the correct sizing.
Second problem:
Situation is the same as above. One TabControl with three TabItems. With workaround from first problem we will ensure for correct sizing of the visuals.
But now the problem: Some labels in XamDataChart on preview or *.xps export are not displayed
Sample is attached
Best regards
Sample - InfragisticsWPFReporting.zip
  • 35319
    I have logged this behavior with our developers in our tracking system, with an issue ID of 146343.  I have also created a support ticket on your behalf with number CAS-119403-W8Y2G8 in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
