Is this a proper behaviour?
I'm using a ScatterLineSeries with NumericXAxis.
I do not set explicite Intervals for the axis. For most cases it works great, soo my axis labels look like this:
| 1992, | 1993, | 1994, | 1995
(off course I'm using DataTemplate for the axis label).
Now, the issue is that, for small number of "x" values, the labels are duplicated!. So, I have this:
| 1992, | 1992, | 1993, | 1993
In other words, there are more labels than x values.
Is there some property to set in order to get rid of duplicated values?
I've double checked my data structures, and they seems fine.
Off course I could set Interval to 1 and have this issues solved, but the problem is that there can be thousands of values (then, having interval set to 1 makes my axis not really readable).
Thank You Martin!
This is exactly what I needed.
Solution is a bit more complicated than I thought, but it works fine!
Hello Lukasz,
Did you review my updated sample and do you have any questions about?
-Martin
I converted my SL application to WPF and I attached it to this message. Let me know if you have more questions about it.
Thanks for the explanation (and sorry for the delay)
Actually I was having problems with your sample. I'm using WPF and your sample is for Silverlight.
Would that be a big effort to convert this sample to WPF world?
Were you able to resolve your issue with Axis labels?
