I have a XamDatagrid in which there is a Field, which I do not want to export to excel. Is there a way to do so (apart from setting its Visibility) by setting a property of field.
I am using this function to do so.
Public Function Export(ByVal dataPresenter As DataPresenterBase, ByVal workbook As Workbook, ByVal startRow As Integer, ByVal startColumn As Integer) As Workbook
Hello Nikhil,
Thank you for your post. I have been looking into it and I can suggest you see this forum thread:
http://ko.infragistics.com/community/forums/t/34093.aspx
where a similar issue is discussed. Please let me know if this helps you or you need further assistance on this matter.
