I have a XamDataGrid showing data with 1-level grouping. I would like to show some white space between each group (the white space is below the last row in each group). Is it possible to achieve this?
Thank you!
Jack,
I am just checking your progress on the issue.
If you have any other questions on the matter, please feel free to ask.
Hello Jack,
Thank you for posting!
White space could be added below each group by setting a style for GroupByRecordPresenter and changing the margin property so that more space is left blank above each group record. In order to remove the space above the top most record a trigger could be added. It checks if the record index is zero and set the margin to “0,0,0,0”:
<Style TargetType="{x:Type ig:GroupByRecordPresenter}">
<Setter Property="Margin" Value="0,50,0,0"/>
<Style.Triggers>
<DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=Record.Index}" Value="0">
<Setter Property="Margin" Value="0,0,0,0"/>
</DataTrigger>
</Style.Triggers>
</Style>
Please feel free to let me know if this helps you.
