The label of my Y-axis is tied to a converter that sets the labels in either whole dollars, K dollars or M dollars. This functionality works initially but doesn’t refresh unless I resize the window or change the data being shown.
I’ve seen other people with similar problems on the forums (http://ko.infragistics.com/community/forums/t/75986.aspx comes to mind), but the button that allows you to switch between the different labels isn’t a property, so I can’t bind to it. In order to change the label, my converter casts the value given to my custom object, then calls that object’s ToString which handles the formatting.
I’m hoping there is just a simple way to get the axis to force refresh in code behind, even without a noticeable change. I’ve tried all the typical UpdateLayout, InvalidateVisual, InvalidateMeasure methods in hopes that those would work, but they weren’t successful either.
Thanks in advance and let me know if more detail is needed.
This worked perfectly, thank you.
Hello Gary,
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Thank you for your post. I have been looking into your question and what I can suggest is using the MinimumValue or MaximumValue of the NumericYAxis to fore the refresh. You can set the MinimumValue for example to some value (0 for example) and then set it to the value that you wish, if you are setting those properties or set to double.NaN, if the range of the axis is automatically generated. I have modified the sample from the thread that you have referred to show how you can use this approach.
Please let me know if you need any further assistance on the matter.
