1675
XamGrid - Cannot change ObservableCollection during a CollectionChanged event
I am using XamGrid which is bounded to collectionviewsource, apparently when i add filter row to the xamgrid (via below xaml) i get the exception "cannot change observablecollection during a collectionchanged event" i.e. when the first row is added to the collection, it seems the gridmanager is initializing the rowfilter when the first row is added.
Appreciate if you could shed some light why i might be getting this exception or how i can avoid it?
I am using the latest service release
<ig:XamGrid x:Name="grid" Grid.Row="1">
<ig:XamGrid.FilteringSettings>
<ig:FilteringSettings AllowFiltering="FilterRowTop" FilteringScope="ColumnLayout">
</ig:FilteringSettings>
</ig:XamGrid.FilteringSettings>
</ig:XamGrid>
at System.Collections.ObjectModel.ObservableCollection`1.CheckReentrancy()
at System.Collections.ObjectModel.ObservableCollection`1.InsertItem(Int32 index, T item)
at System.Collections.ObjectModel.Collection`1.System.Collections.IList.Add(Object value)
at System.Windows.Data.ListCollectionView.AddNewCommon(Object newItem)
at Infragistics.DataManagerBase.GenerateNewObject()
at Infragistics.Controls.Grids.RowsManager.GenerateNewObject(RowType rowType)
at Infragistics.Controls.Grids.RowsManager.ResetFilterRows(Boolean generateNewData)
at Infragistics.Controls.Grids.RowsManager.InitializeData()
at Infragistics.Controls.Grids.RowsManager.ItemsSource_CollectionChanged(Object sender, NotifyCollectionChangedEventArgs e)
at System.Windows.Data.CollectionView.OnCollectionChanged(NotifyCollectionChangedEventArgs args)
at System.Windows.Data.ListCollectionView.ProcessCollectionChangedWithAdjustedIndex(NotifyCollectionChangedEventArgs args, Int32 adjustedOldIndex, Int32 adjustedNewIndex)
at System.Collections.Specialized.NotifyCollectionChangedEventHandler.Invoke(Object sender, NotifyCollectionChangedEventArgs e)
at System.Collections.ObjectModel.ObservableCollection`1.OnCollectionChanged(NotifyCollectionChangedEventArgs e)
at ... <I add value to the underlying collection here>
