How do I change the header area background color? This is the dockpanel that holds the pre and post item content and the tab items.
Chris
Hello Chris,
Thanks again.
It turns out I just had to edit the default control template to get what I wanted. Thanks.
You can also see the code I suggested you here:
http://ko.infragistics.com/products/wpf/sample/tab-control/customizing-the-xamtabcontrol
This is the online version of the Samples Browser, but it contains only the XAML and the C#, you won't be able to interact with the sample since it is on WPF.
Hope this helps you.
I don't see any Samples Browser application. In my Start Menu under Infragistics I see NetAdvantage 2013.1/WPF/Samples/WPF Sample Source Code (Online) 2013.1
-Chris
The Samples Browser is an application installed along with the NetAdvantage product, which contains samples with all our controls, showing their features. You can find it by opening Start Menu and navigate to: All Programs / Infragistics / NetAdvantage 13.1 / WPF / Samples / WPF Samples Browser 13.1. Please let me know if this helps you or you need further assistance on this matter.
