Hi, I had to use SelectRecord as my data grid's CellClickAction, but when I clicked at a cell, I want to know the clicked cell index, is there any way I can get it?
I don't know why you insist on using CellClickAction="SelectRecord" in your application.In answer to your question - "How can I get the selected cell index from ActiveRecord ?"I suggest you the following.
In the Xaml file use this:
<Grid> <igDP:XamDataGrid Name="xamDataGrid1" BindToSampleData="True" Margin="0,0,0,144" SelectedItemsChanged="xamDataGrid1_SelectedItemsChanged"> <igDP:XamDataGrid.FieldSettings> <igDP:FieldSettings CellClickAction="SelectCell" AllowEdit="False"/> </igDP:XamDataGrid.FieldSettings> </igDP:XamDataGrid></Grid>
In the code behind use this:
private void xamDataGrid1_SelectedItemsChanged(object sender, Infragistics.Windows.DataPresenter.Events.SelectedItemsChangedEventArgs e) { DataRecord selectedRecord = (DataRecord) xamDataGrid1.ActiveRecord; Cell selectedCell = xamDataGrid1.ActiveCell; CellCollection cellCollection = selectedRecord.Cells; int indxSelectedCell = cellCollection.IndexOf(selectedCell); MessageBox.Show("The index of the selected cell is :" + indxSelectedCell.ToString()); }
Best Regards,
Yanko
Anybody can help me?
