1339
PerformAutoSize Cannot Size Cell Using Template
Using version 13.1.20131.1009 I'm setting the Template property of the CellValuePresenter for a given Field to show an image next to the text value of each cell:
<Style TargetType="{x:Type igWPF:CellValuePresenter}" x:Key="SomeStyle">
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="{x:Type igWPF:CellValuePresenter}">
<StackPanel Orientation="Horizontal">
<Image Width="16"
Height="16"
Margin="6,0,6,0"
VerticalAlignment="Center"
HorizontalAlignment="Left" />
<TextBlock Text="{Binding Path=DataItem.Item1}" VerticalAlignment="Center" />
</StackPanel>
</ControlTemplate>
</Setter.Value>
</Setter>
</Style>
When I call PerformAutoResize() on this field, it doesn't register any width for the data cells and only accounts for the label:
field.PerformAutoSize(FieldAutoSizeOptions.All, FieldAutoSizeScope.AllRecords);
Please see attached for a project demonstrating this issue.
PerformAutoResize.zip
  • 138253
    Verified Answer
    Thank you for your post. I have been looking into it and I modified the sample you have sent, so now it works as you want. Basically instead of setting the CellValuePresenter’s Template, I set its DataTemplate, because when you set the Template all the built-in functionality is lost. I can suggest you do so in the future or copy the default Style for the CellValuePresenter and modify it. You can find the default Templates here by default:
    C:\Program Files (x86)\Infragistics\NetAdvantage 2013.1\WPF\DefaultStyles
    Please let me know if this helps you or you need further assistance on this matter.
    PerformAutoResizeModified.zip
