I followed the code provided in infragistic samples, for Excel export functionality of WPF Pivot grid.
Export is not copying Row header and Column header into excel file.
Kindly provide the solution/code for this.
Rambabu
Hi Rambabu,
Let me know if you have any further questions on this matter.
I've attached a sample solution that exports the columns, rows and measures used in the XamPivotGrid. I took the code from the Infragistics samples and added some extra code to export the required items.
// Build the columns list. int currentCell = 1; XmlaDataSource datasource = (XmlaDataSource)this.pivotGrid.DataSource; SetCellValue(sheetOne.Rows[0].Cells[0], "Column Dimensions:", "Columns", "Right"); foreach (FilterViewModelBase filterVM in datasource.Columns) SetCellValue(sheetOne.Rows[0].Cells[currentCell++], filterVM.Caption, "Columns"); // reset; currentCell = 1; // Build the rows list. SetCellValue(sheetOne.Rows[1].Cells[0], "Row Dimensions:", "Rows", "Right"); foreach (FilterViewModelBase filterVM in datasource.Rows) SetCellValue(sheetOne.Rows[1].Cells[currentCell++], filterVM.Caption, "Rows"); // reset; currentCell = 1; // Build the measures list. SetCellValue(sheetOne.Rows[2].Cells[0], "Measures:", "Measures", "Right"); foreach (BaseMeasureViewModel measureVM in datasource.Measures) SetCellValue(sheetOne.Rows[2].Cells[currentCell++], measureVM.Caption, "Measures");
Let me know if you have any questions on this.
