I'm using a xamDockManager with a TabGroupPane to create a layout. The xamDockManager uses the metro theme.
I would like to change the colors of the metro theme such that the text is black and the background of the tab is white when the tab is selected. The text should be white and the background of the tab should be black when the tab isn't selected.
I've tried to use the Infagistics Color Tuner to set the colors to black, but the the text still appears to be gray. How can I get the required result?
