This is a duplicate post since i have not heard any acknowledgement (http://ko.infragistics.com/community/forums/t/83474.aspx)
Can someone please confirm if this is a bug? Again i see the same behavior if virtualization is on or off so please ignore the subject line of the previous post
See attached sample
Summary:
If we set "ShouldRefreshOnDataChange" to false, and add a single row to the grid the cpu takes only 3-4% on my box.
If we set "ShouldRefreshOnDataChange" to true, and add a single row, the cpu takes 25% (i.e. one full core)
Try running the attached sample by turning on/off the above property in (TabItem1.xaml.cs) line 51
Per your documentation "ShouldRefreshOnDataChange - Get / set whether this rule needs to reaquire data due to cell value being changed", so it should render only the cell/row which is updated, but apparently as per the trace i see all cells are being repainted in the view port.
Could you please take this urgently with devs and update me if it is a bug and if so when it can be patched? We need conditional formatting, otherwise can you please let me know if there is any other way i can style a row manually when a particular property changes?
Hi Rohit,
Let’s continue our discussion in the above mentioned forum thread. This way other visitors of our community may get benefit from our discussion.
Thank you for understanding.
