i have xamdatagrid and each row contain edit and delete button.when i click on the edit button ,only the corresponding row will be in edit mode.
all other rows will be in read only mode.
initially i had set AllowEdit property to false.
how can i do this.
i am using MVVM model to implement this.
Jafar VM
Hello Jafar,
Thank you for your post. I have been looking into it and it seems like that it is duplicate to this one:
http://ko.infragistics.com/community/forums/t/83604.aspx
so I can suggest you continue the discussion there.
