1320
Change the error message in XamNumericEditor
I'm using the XamNumericEditor and using the mask field to validate the input:
<igWPF:XamNumericEditor Text="{Binding Path=Text,Mode= TwoWay}" IsEnabled="{Binding IsNew, FallbackValue=False}"  Mask="{}{number:1-4}" ValueType="{x:Type sys:Int32}" PromptChar=""/>
Due to localization issues I have to modify the error message that appears when the input isn't valid (for example when 0 is entered). How can I do this?
  • 5600
    You can easily customize the error message using the method described here
    This line of code will change the error message, if you type for example 0:
     Infragistics.Windows.Editors.Resources.Customizer.SetCustomizedString("LMSG_ValueConstraint_MinInclusive", "[Your Text Here.]");
    Do not hesitate to ask, if you have other questions.
    Anastas
