1775
XamGrid - multiple column selection through column header
When user clicks on column header and drags mouse over other column headers,multiple columns should get selected. I am able to achieve column selection on click of column header by Preview mouse down event of header cell control but multiple column selection through click and drag on column headers, I am not able to achieve. Style used for selection of column on column header is:
<Style TargetType="{x:Type igPrim:HeaderCellControl}"     BasedOn="{StaticResource HeaderCellControlStyle}">
      <EventSetter Event="PreviewMouseDown" Handler="HeaderControl_PreviewMouseDown" />
</Style>
Please provide a solution to achive column selection through click and drag of column header. Thanks in advance.
Sasikumar
  • 138253
    Hello Sasikumar,
  • 138253
    Hello Sasikumar,
    Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Basically I handled the HeaderCellControl’s PreviewMouseDown and PreviewMouseMove events in order to make the selection of the Columns. Also I added a check if the Control key is pressed in order to keep the built in functionality for selection using Control. You can add a similar check for the Shift key if you want. Please let me know if this helps you or you need further assistance on this matter.
    XamGridColumnSelectionByDraging.zip
