60
XamTile resize behavior when UseExplicitRowColumnOnTile and tiles with ColumnSpan/RowSpan
I am investigating various layout scenarios using XamTileManager.  I've assembled a layout that looks something like the intended layout image below.  In the image, imagine that the dashed lines are demarcating the edge of XamTileManager.Row/Column(s).  A contiguous color is a single XamTile.  The notation used corresponds to setting attached values on the corresponding XamTile as follows:
C* => XamTileManager.Column set to * value
R* => XamTileManager.Row set to * value
CSPAN* => XamTileManager.ColumnSpan set to * value
RSPAN* => XamTileManager.RowSpan set to * value
Additionally the NormalModeSettings I am using are:
      <ig:XamTileManager.NormalModeSettings>
        <ig:NormalModeSettings
          AllowTileDragging="Slide"
          AllowTileSizing="Individual"
          TileLayoutOrder="UseExplicitRowColumnOnTile" />
      </ig:XamTileManager.NormalModeSettings>
I am expecting the resulting visualization to be similar to the image attached.  On initial rendering the 4 tiles in the upper left look to be evenly placed across 2 rows and 2 columns.  I am able to adjust this to a small degree to achieve something _relatively_ similar to what I am looking for.  However, I was expecting to have more explicit control over individual Tile(/Column/Row) sizes.  Almost none of the results of dragging on an edge are what I would intuitively expect.  It seems to be worse for edges that intersect with a tile that spans.
There's not much documentation on how layout should work when dealing with UseExplicitRowColumnOnTile and spanning columns/rows.  Can you elaborate on what is expected (because what I observe is definitely not what I would expect, nor does it seem natural).
What I was expecting was that I would be able to drag an edge and it would effectively allow me to resize the "logical" (not as in Logical tree, literally meaning logical) row/column to the point that it is flush up against the adjacent one for inner edges.  I would have at least have expected to get a layout that is exactly as the first image attached (by adjustment if not initial layout given the column/row/spans).
