1675
Switch dataset by recycling the cells
I have two data sets that i want to quickly switch back and forth on the grid. Both the datasets are type observablecollection and the column order, style are the same, so i want to recycle the cells, at present when i switch between the two ItemSources I see that all the cells are re-created and this takes up a few seconds. As the user of my app would do this multiple times in a day the slight pause looks very annoying to them.
Is there a way or a property that I can use so the grid could recycle the cells instead of creating all cells from scratch when the underlying source is switched?
Rohit
