The control is assigned to Obs<> datasource and when I update one of the object "UpdateDateTime" (data type datetime), the cards do not get sorted.
Is there a way I can force the sorting after a change in the datasource updates?
I have also made the fields visible and I do see the value updated, but it cards do not get sorted.
I have the same issue with both the example code. Thanks for help
Example 1:
<DataPresenter:XamDataCards x:Name="xamDataCards" Theme="Aero" HorizontalContentAlignment="Stretch" ScrollingMode="DeferredWithScrollTips"> <DataPresenter:XamDataCards.ViewSettings> <DataPresenter:CardViewSettings MaxCardCols="1" AllowCardHeightResizing="True" AllowCardWidthResizing="True" CollapseCardButtonVisibility="Visible" HeaderPath="RollingNoteDescription" HeaderVisibility="Visible" ShouldAnimateCardPositioning="False" /> </DataPresenter:XamDataCards.ViewSettings>
<DataPresenter:XamDataCards.FieldLayoutSettings> <DataPresenter:FieldLayoutSettings AutoArrangeCells="Never" AutoGenerateFields="False" DataRecordSizingMode="SizedToContentAndIndividuallySizable" AllowFieldMoving="No" HighlightAlternateRecords="True" AutoFitMode="ExtendLastField" HighlightPrimaryField="SameAsOtherFields"/> </DataPresenter:XamDataCards.FieldLayoutSettings>
<DataPresenter:XamDataCards.FieldLayouts> <DataPresenter:FieldLayout> <DataPresenter:FieldLayout.SortedFields> <DataPresenter:FieldSortDescription Direction="Descending" FieldName="UpdatedDateTime" /> </DataPresenter:FieldLayout.SortedFields> <DataPresenter:Field Name="Notes" Row="0" Column="0" Label="" Height="Auto" Width="Auto" > <DataPresenter:Field.Settings> <DataPresenter:FieldSettings AllowEdit="False" AutoSizeOptions="DataCells" > </DataPresenter:FieldSettings> </DataPresenter:Field.Settings> </DataPresenter:Field> <DataPresenter:Field Name="UpdatedDateTime" Row="3" Column="0" Label="" Height="Auto" Width="Auto" Visibility="Collapsed"> <DataPresenter:Field.Settings> <DataPresenter:FieldSettings AllowEdit="False" AutoSizeOptions="DataCells" > </DataPresenter:FieldSettings> </DataPresenter:Field.Settings> </DataPresenter:Field> </DataPresenter:FieldLayout> </DataPresenter:XamDataCards.FieldLayouts> </DataPresenter:XamDataCards>
Eaxmple 2:
<DataPresenter:XamDataCards Grid.Row="1" x:Name="xamDataCards" Theme="Aero" HorizontalContentAlignment="Stretch" ScrollingMode="DeferredWithScrollTips"> <DataPresenter:XamDataCards.ViewSettings> <DataPresenter:CardViewSettings MaxCardCols="1" AllowCardHeightResizing="True" AllowCardWidthResizing="True" CollapseCardButtonVisibility="Visible" HeaderPath="RollingHeader" HeaderVisibility="Visible" ShouldAnimateCardPositioning="False" /> </DataPresenter:XamDataCards.ViewSettings>
<DataPresenter:XamDataCards.FieldLayouts> <DataPresenter:FieldLayout> <DataPresenter:FieldLayout.SortedFields> <DataPresenter:FieldSortDescription Direction="Descending" FieldName="UpdateDate" /> </DataPresenter:FieldLayout.SortedFields> <DataPresenter:Field Name="Comments" Row="0" Column="0" Label="" Height="Auto" Width="Auto" > <DataPresenter:Field.Settings> <DataPresenter:FieldSettings AllowEdit="False" AutoSizeOptions="DataCells" > </DataPresenter:FieldSettings> </DataPresenter:Field.Settings> </DataPresenter:Field>
<!--DataPresenter:Field Name="RollingHeader" Row="2" Column="0" Label="" Height="Auto" Width="Auto" > <DataPresenter:Field.Settings> <DataPresenter:FieldSettings AllowEdit="False"> <DataPresenter:FieldSettings.EditorStyle> <Style TargetType="{x:Type igEditors:XamDateTimeEditor}"> <Setter Property="ValueToTextConverter" Value="{StaticResource dateTimeValueConverter}"/> <Setter Property="ValueToDisplayTextConverter" Value="{StaticResource dateTimeValueConverter}"/> </Style> </DataPresenter:FieldSettings.EditorStyle>
</DataPresenter:FieldSettings> </DataPresenter:Field.Settings> </DataPresenter:Field--> <DataPresenter:Field Name="UpdateDate" Row="3" Column="0" Label="" Height="Auto" Width="Auto" Visibility="Collapsed"> <DataPresenter:Field.Settings> <DataPresenter:FieldSettings AllowEdit="False" AutoSizeOptions="DataCells" > </DataPresenter:FieldSettings> </DataPresenter:Field.Settings> </DataPresenter:Field> </DataPresenter:FieldLayout> </DataPresenter:XamDataCards.FieldLayouts> </DataPresenter:XamDataCards>
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into it and I can suggest you call the XamDataCards’ Records’ RefreshSort method in order to refresh the sorting, when the Records are modified.
Anyone who can help? Thanks
