On WinForm I have added WPF control (Infragistic's XamSyntaxEditor)
http://stackoverflow.com/questions/4350862/wpf-events-in-winforms
But I am not sure how to write or hook custom event with WPF control events .
Hello Aparna,
I have logged this with development under ID: 156848 and I have also created a support ticket on your behalf: CAS-125241-B4Q3Y0 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
Hi Stefan ,
Using Append method crash doesnt occured in code which I have provided , But if I use append instead of initialize text in my actual class crash still exist.
Also if append intead of initialize text doesnt serv the actual purpose , even if I add condition checks etc in some scenarios text get appended .
What is exact cause of this error ? How I can resolve it ?
I have been looking into the sample you have attached and I was able to reproduce the first exception you mentioned and I can suggest you use the Document's Append method instead of InitializeText one on the setter of the Text property. Could you please try this and see if the second exception will continue to occurs.
I have attached sample which reproduce crash mentioned above .
(Note : To run EXE you need to change Infragistics DLL references to yur local DLL references,I have removed DLL as f they were causing huge size of zip file upto 6MB )
When you run EXE 1st time you will get Argumet exception in TextDocument and Compatability Error .
On Compatibility Error when youe click on Close button .
Again Run EXE now you will get argumentNullReference Exception in XamSyntaxEditor ,related to parameter 'newOrReformattedLines'
Looking forward for your feddback on this issue.
I have been looking into the exception, but since this is not a known issue, without a sample project, where this is reproduced we are not able to investigate this further for you.
