625
XamDataGrid - 'Collection was modified' exception when dragging column from chooser onto grid.
We're using XamDataGrid v.11.2 and are experiencing an issue when our application is run on Windows Server 2003 Standard.
On the problem machine we are able to reproduce the issue by doing the following:
1. Open the column chooser
2. Click a column in the chooser which is already visible in the grid
3. Drag the column from the chooser to a different location in the grid (effectively move the column from its original location to a new location)
Upon dropping the column into its new location, the app will crash and we get a stack trace that looks like:
System.InvalidOperationException: Collection was modified; enumeration operation may not execute.
at System.ThrowHelper.ThrowInvalidOperationException(ExceptionResource resource)
at System.Collections.Generic.List`1.Enumerator.MoveNextRare()
at System.Collections.Generic.List`1.Enumerator.MoveNext()
at Infragistics.Controls.Layouts.Primitives.GridBagLayoutManager.ResizeManager.CloneLayoutManagerHelper(GridBagLayoutManager source)
at Infragistics.Controls.Layouts.Primitives.GridBagLayoutManager.ResizeManager..ctor(GridBagLayoutManager layoutManager, ILayoutContainer layoutContainer, Object containerContext, Boolean autoFitWidth, Boolean autoFitHeight)
at Infragistics.Windows.DataPresenter.DataPresenterBase.Infragistics.Windows.Resizing.IResizeHost.InitializeResizeConstraints(FrameworkElement resizeArea, FrameworkElement resizableItem, ResizeConstraints constraints)
at Infragistics.Windows.DataPresenter.DataPresenterBase.Infragistics.Windows.Resizing.IResizeHost.CanResize(FrameworkElement resizableItem, Boolean resizeInXAxis)
at Infragistics.Windows.Resizing.ResizeController.GetElementToResize(FrameworkElement element, MouseDevice mouseDevice, Nullable`1& processWidth)
at Infragistics.Windows.Resizing.ResizeController.OnQueryCursor(Object sender, QueryCursorEventArgs e)
at System.Windows.Input.QueryCursorEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.MouseDevice.UpdateCursorPrivate()
at System.Windows.Input.MouseDevice.PostProcessInput(Object sender, ProcessInputEventArgs e)
at System.Windows.Input.InputManager.RaiseProcessInputEventHandlers(ProcessInputEventHandler postProcessInput, ProcessInputEventArgs processInputEventArgs)
at System.Windows.Input.MouseDevice.Synchronize()
at System.Windows.Input.MouseDevice.ChangeMouseCapture(IInputElement mouseCapture, IMouseInputProvider providerCapture, CaptureMode captureMode, Int32 timestamp)
at System.Windows.Input.MouseDevice.PreNotifyInput(Object sender, NotifyInputEventArgs e)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.SafeNativeMethods.SafeNativeMethodsPrivate.IntReleaseCapture()
at MS.Win32.SafeNativeMethods.ReleaseCapture()
at System.Windows.Interop.HwndMouseInputProvider.System.Windows.Input.IMouseInputProvider.ReleaseMouseCapture()
at System.Windows.Input.MouseDevice.Capture(IInputElement element, CaptureMode captureMode)
at Infragistics.Windows.DataPresenter.FieldChooser.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.UIElement.OnMouseLeftButtonUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run(Window window)
at System.Windows.Application.Run()
at MyApp.App.Main()
This exception is happening outside of our own application code.  We are not modifying the collection of columns.  This appears to be a bug in XamDataGrid.  We've tried Windows Server 2008 R2, Windows 7 and are not able to reproduce this issue on those operating systems.
Advise?
Paul
