We are using Infragistics 13.1 and having this issue from time to time using XamDataGrid.
Any ideas?
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at Infragistics.Windows.DataPresenter.DataPresenterBase.RecordSelectionEnumerator.GetNextSiblingRecord(Int32 levelIndex, Boolean& retry)
at Infragistics.Windows.DataPresenter.DataPresenterBase.RecordSelectionEnumerator.MoveNext()
at Infragistics.Windows.DataPresenter.DataPresenterBase.GetRecordsForSelection(Boolean select, RangeSelectionEvaluator evaluator)
at Infragistics.Windows.DataPresenter.DataPresenterBase.CalculateSelectionRange(Cell cell, SelectedItemHolder newSelection, Boolean clearExistingSelection, Boolean select)
at Infragistics.Windows.DataPresenter.DataPresenterBase.CalculateNewSelectionRange(ISelectableItem item, Boolean clearExistingSelection, Boolean select)
at Infragistics.Windows.DataPresenter.DataPresenterBase.InternalSelectRange(ISelectableItem item, Boolean clearExistingSelection, Boolean select)
at Infragistics.Windows.DataPresenter.DataPresenterBase.Infragistics.Windows.Selection.ISelectionHost.SelectRange(ISelectableItem item, Boolean clearExistingSelection)
at Infragistics.Windows.Selection.SelectionStrategyExtended.OnMouseMove(ISelectableItem item, MouseEventArgs e)
at Infragistics.Windows.Selection.SelectionController.OnMouseMove(MouseEventArgs e)
at Infragistics.Windows.Controls.IGControlBase.OnMouseMove(MouseEventArgs e)
at Infragistics.Windows.DataPresenter.DataPresenterBase.OnMouseMove(MouseEventArgs e)
at System.Windows.UIElement.OnMouseMoveThunk(Object sender, MouseEventArgs e)
at System.Windows.Input.MouseEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
Hi Stefan,
We haven't turnover yet, I don't know when it will happen so for now we can end that thread, I will open a new one if the issue still occur after our turnover.
Dominik
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thank you for your post. I have been looking into it and I can say that there are two similar issues that are fixed in the ;attest service releases of 12.2 and 13.1, so I can suggest you download them. You can do this by logging to our web site and going to Account \Keys & Downloads.
https://ko.infragistics.com/my-account/keys-and-downloads/
If this doesn’t fix your issue, could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
