Hi
any idea what formula is used by NumericYAxis to calculate auto interval?
Hello Mudassir,
I've provided you with the basic idea of the algorithm. If you wish to see the exact implementation, I'll gladly navigate you through the source code of the control. In order to get the source code you can read this topic. You can find what you need to do in order to get it. After that, I can guide you where exactly is the implementation of that logic.
Martin Stoev
Hi again!
i guess you didn't answer the question yet, you give the hint but didn't tell the exact interval calculation
i am still struggling to calculate interval.
Hello again Mudassir,
If you have any other questions about this matter, please don't hesitate to ask.
Yes, there might be some cases in my explanation, where it will be different from the actual algorithm. The reason is because I can provide you with the basic idea.
Thank you for your understanding,
Well even this is not the accurate solution.
change series and the results will be exploded.
anyhow thanks for the efforts you made.
