i want user to able to move row Up/down manually by selecting row and dragging it. please provide a sample code as Example.
i have searched infragistic and found http://ko.infragistics.com/community/forums/t/53245.aspx but it doesn't have any sample code or how this task is achieved.
Thanks,kamlendra
Hello Kamlendra,
I am looking forward to hear from you.
Hi Stefan,
i will create asample and share with you. As its new Iteration i will be able to share it after Monday.
Regards,Kamlendra
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
I have been looking into your post, and it will be better if you send an isolated sample project, where the issue is reproduced, so I can investigate it further for you, because I cannot be completely sure how your data is organized and how exactly you wrapped the DragSource_Drop event into attached behavior.
