85
Customizing the ribbon buttons
Hello!
Is there a possibility to customize the ribbons igRibbon:ButtonTool.
I'd like to change e.g. the hover boder to 2px without any radius. I had a look at the theme Xaml files to override the whole control but I'm not sure this is supported or these styles are included.
Wolfgang
  • 54937
    Verified Answer
    This post describes how the ButtonTool is styled. The RibbonButtonChrome that does the rendering for the tool doesn't expose a way to control the thickness of the borders but you can disable the rounding by setting its UseRoundedCorners to false. Note this will turn off the rounding for all states (e.g. checked, hover, etc.). This property was added in 12.1 as it was needed for the Metro themes. If you wanted to set this then you would need to copy the default styles provided with the product and use those modified resource dictionaries.
