we want to set an initial column width and therefore need to activate text wrapping in column headers. I found some messages about this problem in the forum but no solution how to realize that.
Up to now I tried the following:
1. I create a TextColumn in code behind:
TextColumn col = new TextColumn();col.Key = "[rg" + iRG.ToString() + "fct" + iF.ToString() + "]";col.HeaderText = _selFacts[iF - 1].Name;col.Width = new ColumnWidth(100, false);col.HeaderTemplate = (DataTemplate)FindResource("HeaderCellTemplateForTextWrapping");
The Key is created dynamically and the HeaderText is the name of a Fact (e.g. "Turnover [abs.]"). I set the HeaderTemplate.
2. I define the DataTemplate in XAML:
<DataTemplate x:Key="HeaderCellTemplateForTextWrapping" DataType="{x:Type igPrim:HeaderCellControl}"> <TextBlock Text="{Binding HeaderTextProperty}" TextWrapping="WrapWithOverflow" /></DataTemplate>
I alsol tried setting the Datatype to "ig:TextColumn" and tried different Bindings like:
Text="{Binding Path=TextColumn.HeaderText}" Text="{Binding Path=HeaderText}" Text="{Binding Path=HeaderTextProperty}" Text="{Binding Path=TextColumn.HeaderTextProperty}
Up to now nothing worked. I only get empty header cells. Could you please tell me what I must do to get text wrapping?
Regards
Hello Yanko,
thank you very much. That's exactly what we need!
Thank you for your reply. I have been looking into your requirement and you need to define the DataTemplate like :
<DataTemplate x:Key="header">
<TextBlock Text="{Binding RelativeSource={RelativeSource FindAncestor, AncestorType=igPrim:HeaderCellControl, AncestorLevel=1}, Path=Column.HeaderText}"
TextWrapping="Wrap"/>
</DataTemplate>
I am attaching a modified version of my sample application(xamGridHeaderTextWrapping2.zip) that shows this approach.
Let me know, if you need any further assistance on this matter.
thank you for the sample.
According to your sample I changed my application, but I got the same result I already achieved. In the header I only see the key.
This is not what I need. I create all TextColumns dynamically and therefore each column must get an unique key. The text shown in the column header, which I need to wrap, is asigned to the property "HeaderText".
Could you please show me a solution for this constellation?
I have been looking into your requirement and the easiest way to achieve text wrapping of the header of the columns in the XamGrid is to define a header template with a TextBlock and set its ‘TextWrapping’ property. After that you will set this header template to the columns in the ‘ColumnLayoutAssigned’ event of the XamGrid like e.g. :
<DataTemplate>
<TextBlock Text="{Binding}"
private void xamGrid1_ColumnLayoutAssigned(object sender, ColumnLayoutAssignedEventArgs e)
foreach (var item in e.ColumnLayout.Columns)
item.HeaderTemplate = this.Resources["header"] as DataTemplate;
I am attaching a sample application(xamGridHeaderTextWrapping.zip) that shows this approach.
Please let me know, if you need any further assistance on this matter.
