350
XamNumericEditor's dynamic SpinIncrement?
I need to have XamNumericEditor's SpinIncrement value depend on the current editor's value. For example:
- if value is in the range of 0 - 100, the increment must be 1
- if value is in the range of 100-1000, the increment must be 10
- if value is above 1000, the increment must be 1000
Is there any way to achieve the above mentioned functionality using XamNumericEditor?
Alex
  • 22852
    Verified Answer
    Alex,
    Another approach would be to bind the SpinIncrement property to the Value property and use a converter to set the increment.  For example:
    XAML:
    <Grid>
        <Grid.Resources>
            <local:SpinIncrementConverter x:Key="SpinIncrementConverter"/>
        </Grid.Resources>
        <igEditors:XamNumericEditor SpinButtonDisplayMode="Always" SpinIncrement="{Binding RelativeSource={RelativeSource Self}, Path=Value, Mode=OneWay, Converter={StaticResource SpinIncrementConverter}}"></igEditors:XamNumericEditor>
    </Grid>
    C#:
    public class SpinIncrementConverter : IValueConverter
        public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
            double newValue = 0;
            int increment = 1;
            if (value is double)
                newValue = (double)value;
                if (newValue >= 100)
                    increment = 10;
                if (newValue >= 1000)
                    increment = 1000;
            return increment;
        public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
            throw new NotImplementedException();
    Let me know if you have any questions with this matter.
  • 22852
    Alex,
    The SpinIncrement property of the XamNumericEditor controls how much the spin buttons change the value and you can handle the ValueChanged event and set it in the event handler:
    private void NumericEditor_OnValueChanged(object sender, RoutedPropertyChangedEventArgs<object> e)
        XamNumericEditor editor = sender as XamNumericEditor;
        if (e.NewValue is double)
            newValue = (double)e.NewValue;
        if (editor != null)
            int increment = 1;
                increment = 10;
                increment = 1000;
            editor.SpinIncrement = increment;
