Hello, Our clients have obstacles to upgrade the application using above .NET 4.0 for now. However there is a fix in the latest version that they prefer to use. Does professional 2013 vol2. support .NET 3.5?
Thanks for your reply,
Juan
Hi Juan,
As far I understand from your questions you want to use the 13.2 version with .Net 3.5? If so we are not supporting .Net 3.5. Since June 2011, most of the controls we shipped in WPF were CLR 4 only. Starting with the 12.2 release, we are shipping version CLR 4.0 assemblies. We will fully support CLR 4.0 and CLR 4.5.
You can find more details on this blog here: http://ko.infragistics.com/community/blogs/jason_beres/archive/2012/05/29/updated-support-for-clr-versions-and-visual-studio-versions.aspx
And you can see also our updated site of the supported environments page here: http://ko.infragistics.com/help/supported-environments/
Thank you very much for your reply.
Our client currently on version 20121.2059 (WPF ) CLR3.5 assemblies. There is a fix that we would like to get is in version 20122.2057. From your previous email it looks like infragistics does not support CLR3.5 for version 2012.2, correct?
Is there anyway that we could get this fix in CLR3.5 assemblies?
The build 2012.2 2057 bas released in December 2012, where 20121.2059 was released in July 2012 so there is more recent service release for this version and all service release after Dec. should contain the fixes included in Dec SR (20122.2057) we ship in Dec for 2012.2. So basically I believe that if you take the latest service release for 2012.1 version you will be able to get the fix. For your reference the latest service release for 2012.1 is 2314 and is from May 2013. Can you please try to download it and test if the fix persist. Also if you tell me the issue number I will double check in which service release was included.
Thank you very much for your reply. Unfortunately I do not know the issue number. However the information I got was from the following discussion in the forums.
http://ko.infragistics.com/community/forums/p/73435/429837.aspx#429837
Maybe you could help me to find out if latest service release of 2012.12134) includes this fix or not?
Thanks again,
I am just checking if you manage to download the desired service release and you got the issue fixed at your side?
