i am not able to upload an image on infragisitcs website from my system . so, i am posted my question here.
http://stackoverflow.com/questions/20992041/infragistic-zoombar-size-change-default-value
Kamlendra
Hello Kamlendra,
Thank for your post. I have been looking into it and I can sat that you can add images by pressing the Options tab while you are composing your post and there you can upload an image. As for the question about the xamzoombar, as Damyan suggested in the Stackoverflow thread, you can see this Data Chart Integration (identical Silverlight live version) samples.
As described in the documentation the Zoombar's thumb location and size are determined by the range, so looking at your image I think you want range like { 0.9 - 1 }: <ig:XamZoombar>
<ig:XamZoombar.Range>
<ig:Range Minimum="0.9" Maximum="1"/>
</ig:XamZoombar.Range>
</ig:XamZoombar>
Adjust the minimum value to match what you want to achieve and check out the documentation/sample for snippets to set it in code. Please let me know if this helps you or you have further questions on this matter.
Hi Stefan,
the solution provided by you helps me to achieve what i want. but i am loosing synchronization with my chart.
My Chart:
<ig:XamDataChart x:Name="xmDataChart" DataContext="{Binding Path=SelectedDevice.RFMonitorData}" Margin="30,20,30,0" Background="Transparent" PlotAreaBackground="Transparent" HorizontalZoomable="True" HorizontalZoombarVisibility="Collapsed" VerticalZoomable="False" VerticalZoombarVisibility="Collapsed" OverviewPlusDetailPaneVisibility="Collapsed" > <ig:SyncManager.SyncSettings> <ig:SyncSettings SyncChannel="charts" SynchronizeHorizontally="True" SynchronizeVertically="False" /> </ig:SyncManager.SyncSettings>
My ZoomBar:
<ig:XamZoombar Name="xamZoombar1" VerticalAlignment="Top" Background="Transparent" Opacity=".8" Range="{Binding ElementName=xmDataChart, Path=HorizontalZoombar.Range, Mode=TwoWay}" >
please let me know how can i sync with my chart and at the same time have the range between 0.9 to 1.
I used your code in order to modify the sample i sent you before, and the OnXamZoombarZoomChanged event doesn't fire on start up, but once i clicked it and the event fires, nothing changes, so I am still not able to fully understand your requirement. Could you please try to modify the sample, so it reproduces your issue and add a screenshot of the desired result in the archive, so I could be able to investiagte this further?
i have uploaded images https://ko.infragistics.com/my-account/support-case/CAS-129688-V0X3B1 (the cases allow us to upload images w/o url).i feel the only culprit in this problem is : initially this.Chart object is getting null so this.Chart.WindowRectChanged event never getting registered.
i am using 2 chart objects. 1) <ig:XamDataChart x:Name="xmDataChart" DataContext=... (for lower part, big chart in image)2) (The Other one is child of zoombar in HorizontalPreviewContent) which is synchronized with the main (Name:"xmDataChart") <ig:XamZoombar Name="xamZoombar1" VerticalAlignment="Top" Background="Transparent" Margin="5,5,50,5"
Range="{Binding ElementName=xmDataChart, Path=HorizontalZoombar.Range, Mode=TwoWay}" Opacity=".8"> <ig:XamZoombar.HorizontalPreviewContent> <ig:XamDataChart DataContext="{Binding
Is this causing the this.Chart object in the behaviour class as null and not registring the event this.Chart.WindowRectChanged .hope by seeing the images it will be clear.
Kamlendra,
The chart displayed in XamZoomBar is a preview of the chart that is bound to XamZoomBar. The preview chart (the one in the zoombar) displays all data while the other one shows only the zoomed area. This allow user to know which part of the chart is actually zoomed in. If you need, you can zoom in or out the preview chart, too. I have modified the sample application that was uploaded to this thread by adding interaction behavior to the xmPreviewDataChart chart so the displayed data is modified when the thumb size is changed.
HI maria,
it worked. Thanks a lot!!The issue was: using the behavior twice(in zoom char and zoombar as well).i was using it once only. so the Chart object was null in the behavior class. now its resolved.
Thanks again!!
Thank you for your feedback Kamlendra!
I am glad that this approach helped you.
