How can i filter xamdatatreenode so that only matching cases are displayed in the xamdatatree?
The approach I gave you is just a guidance, which you can use as basis to achieve the functionality you want. Also you if you need to implement any custom scenarios, as the ability to filter on any level and highlight the results, you can contact our Consulting Team. You can read more detailed information regarding this here in our web site:
http://d3.infragistics.com/
Hi .
I I checked the suggested link.I was discussing there as well.The sample project filters as far as i type level one names like item 0,item 1... But this sample does not include feature to filter node at any level. I want it to work in a way that if i type "Item 0 1 0" it only show this node and of course its parent(i.e a like vs solution explorer search).
Can you extend this sample to have vs2012 solution explorer search feature?
thanks.
Hello Kabinad,
Thank you for your post. I have been looking into it and I can suggest you see this forum thread:
http://ko.infragistics.com/community/forums/t/86220.aspx
where a similar question is already discussed. Please let us know if this helps you or you have further questions on this matter.
