155
Attempting to insert Field into an XamDataGrid's FieldLayout.Fields 0th index still visually appears as a second column
When attempting to Insert a new field at index 0 on XamDataGrid.FieldLayout.First().Fields, it consistently appears visually in the second column, despite it properly being assigned the 0th index.  In fact, .Fields.Insert(0, field) visually appears exactly the same as .Fields.Insert(1, field)
I am attempting to insert a new column to certain XamDataGrids via a DependencyProperty, which when set to True, calls an XamDataGrid_Loaded() event:
        static void xamDataGrid_Loaded(object sender, RoutedEventArgs e)
            var grid = sender as XamDataGrid;
            var field = new UnboundField
                Name = "MaxAlertSeverity",
                Label = string.Empty,
                Width = FieldLength.Auto,
                Settings = new FieldSettings()
                    CellValuePresenterStyle = Application.Current.Resources["AlertIndicatorCellValuePresenter"] as Style,
                    AllowSummaries = false,
                    AllowRecordFiltering = false,
                    AllowFixing = AllowFieldFixing.No
            var fieldLayout = grid.FieldLayouts.First();
            var bkn = fieldLayout.Fields.Where(f => f.Name == "BKN").First();
            var bknPos = fieldLayout.Fields.IndexOf(bkn);
            if (bknPos > 0)
                fieldLayout.Fields.Insert(bknPos, field);
            else
                // weird hack to place caution indicators in first column
                fieldLayout.Fields.Remove(bkn);
                fieldLayout.Fields.Insert(0, field);
                fieldLayout.Fields.Insert(1, bkn);
This behavior only occurs if I am trying to insert at index 0, at which point it still visually appears to the right of the first column.  I attempted to “hack” it demonstrated on the else block above, but even removing and re-inserting the original first column despite re-inserting it at index 1 still kept the original column visually appearing first.  In short, I would like my newly inserted column to appear just before the column with the name “BKN”, even if BKN is originally the first column.
  • 155
    Verified Answer
    Resolved via one of the plethora of obscure properties available on XamDataGrid:
    grid.FieldLayoutSettings.AutoArrangePrimaryFieldReservation = AutoArrangePrimaryFieldReservation.None;
