Hi exprts, need ur help again~
say I have Line A and line B. if A[colum1] and B[column1] has the same value, i'd like to merge these 2 cells, and keep following columns still in diffrent two lines.
Please help! Thanks.
Hello Ming,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thank you for your post. I have been looking into it and I can suggest you see this forum thread:
http://ko.infragistics.com/community/forums/t/62864.aspx
where a similar issue is already discussed. Please let me know if this helps you or you have further questions on this matter.
