932
How to set value of a column based on other columns!
Is it possible to write an expression that will set value of a column based on other columns in XamDataGrid?
something like Column3 = Column1.value + Column2.value / Column4.value;  This is supported on System.Data.DataColumn
http://msdn.microsoft.com/en-us/library/system.data.datacolumn.expression.aspx
Any help is appreciated.
Naveen
  • 9694
    Hello Naveen,
    Check out the xamDataGrid NetAdvantage for WPF documentation and look up the "Using an Unbound Field to Display a Complex Property (XAML)" page in the Accessing Data section. Note there is a code-behind page as well (same title without the XAML ending). The page shows how to bind an Unbound Field to a property. In this example, you would do your calculations in the ObjectDataProvider action method (declared in the MethodName property). You could also do the same thing by binding to a DependencyProperty in your code-behind.
    Let me know if you need more help on this topic.
