Hello!
I need a way to initialize FlatDataSource from code. I use MVVM pattern and currently FlatDataSource in my ViewModel is populated with initial items and initialized only after view have been initialized. Now if I want to do something with initialized datasource, I do this in ResultChanged event handler. But this breaks View-ViewModel separation and I can't properly test my code.
Maybe I'm missing something? How can I initialize FlatDataSource with items from ItemsSource without loading the PivotGrid?
Here is my code to generate FlatDataSource:
DataSource = new FlatDataSource { ItemsSource = Items, Cube = DataSourceBase.GenerateInitialCube("DistributorInventory"), Rows = DataSourceBase.GenerateInitialItems("[Distributor].[Distributor]"), Columns = DataSourceBase.GenerateInitialItems("[Date].[Date]"), Measures = DataSourceBase.GenerateInitialItems("Value") };
var cubeMetadata = new CubeMetadata { DisplayName = "Cube", DataTypeFullName = typeof(DistributorInventory).FullName }; cubeMetadata.DimensionSettings.Add(new DimensionMetadata { SourcePropertyName = "Value", DisplayName = "Value", });DataSource.CubesSettings.Add(cubeMetadata);
var datesHierarchy = new HierarchyDescriptor(p => p.Date) {HierarchyDisplayName = "Date"}; datesHierarchy.AddLevel(p => p.MonthText, "Month"); datesHierarchy.AddLevel(p => p.WeekText, "Week"); DataSource.AddHierarchyDescriptor(datesHierarchy);
var itemsHierarchy = new HierarchyDescriptor(p => p.Distributor) {HierarchyDisplayName = "Distributor"}; itemsHierarchy.AddLevel(p => p.Distributor, "Distributor"); itemsHierarchy.AddLevel(p => p.Address, "Address"); itemsHierarchy.AddLevel(p => p.Item, "Item");DataSource.AddHierarchyDescriptor(itemsHierarchy);
DataSource.ResultChanged += OnDataSourceOnResultChanged;
I have logged this with development under ID: 169353 and I have also created a support ticket on your behalf: CAS-134647-L9H5F6 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
Hello?
I just want to know that if my question is being reviewed or not.
I'm just checking if my attached example was helpful or if you need additional info from me.
Thanks!
Yes, I have tried this too but no luck :(
Look, I have a repro example for you, I think this will help you to understand my problem and help me solve it.
What I mean is to make sure you have removed/commented out this line of code:
// do not set the items source yet// ItemsSource = Items,
and put it at the very end of your initialization code:
DataSource.ItemsSource = Items;
Regards,Plamen
