Hello Support,
We are using Infragistics WPF XamDataGrid v12.1.20121.2314. In XamDataGrid, we want to display a dropdown for which we have added a template column as XamComboEditor. But the issue with this templated column is that for selecting any values from the dropdown, user has to double click the dropdown.
You can replicate the issue with the sample code which we have attached in this post. Can you please let us know if there is any way that we can start the XamComboEditor edit mode in single click when its drop down arrow is clicked or when its text area is focused.
Thank you for your post. I have been looking into it and I can suggest you use only a XamComboEditor, not a XamComboEditor with a XamComboEditor in its Template and EditTemplate if you want a single click to put the editor in edit mode. Please let me know if this helps you or you have further questions on this matter.
