1240
XamlParseException
I'm getting an XamlParseException "Provide value on 'System.Windows.Markup.StaticsExtension' deep in Infragistics code.  There are two UI threads with very similar call stacks when the exception occurs.
The exception detail is:
System.Windows.Markup.XamlParseException occurred
  HResult=-2146233087
  Message=Provide value on 'System.Windows.Markup.StaticExtension' threw an exception.
  Source=PresentationFramework
  LineNumber=0
  LinePosition=0
  StackTrace:
       at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
  InnerException: System.Reflection.TargetInvocationException
       HResult=-2146232828
       Message=Exception has been thrown by the target of an invocation.
       Source=mscorlib
       StackTrace:
            at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
            at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
            at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
            at System.Reflection.RuntimePropertyInfo.GetValue(Object obj, BindingFlags invokeAttr, Binder binder, Object[] index, CultureInfo culture)
            at System.Reflection.RuntimePropertyInfo.GetValue(Object obj, Object[] index)
            at System.Windows.Markup.StaticExtension.GetFieldOrPropertyValue(Type type, String name, Object& value)
            at System.Windows.Markup.StaticExtension.ProvideValue(IServiceProvider serviceProvider)
            at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CallProvideValue(MarkupExtension me, IServiceProvider serviceProvider)
       InnerException: System.Xaml.XamlParseException
            HResult=-2146233088
            Message=Exception of type 'System.Xaml.XamlParseException' was thrown.
            LineNumber=0
            LinePosition=0
            StackTrace:
                 at System.Windows.Baml2006.Baml2006Reader.ReadObject(KeyRecord record)
                 at System.Windows.ResourceDictionary.CreateObject(KeyRecord key)
                 at System.Windows.ResourceDictionary.OnGettingValue(Object key, Object& value, Boolean& canCache)
                 at System.Windows.ResourceDictionary.OnGettingValuePrivate(Object key, Object& value, Boolean& canCache)
                 at System.Windows.ResourceDictionary.GetValueWithoutLock(Object key, Boolean& canCache)
                 at System.Windows.ResourceDictionary.GetValue(Object key, Boolean& canCache)
                 at System.Windows.ResourceDictionary.get_Item(Object key)
                 at Infragistics.Windows.Themes.ResourceSet.GetSealedResource(ResourceDictionary dictionary, Object key)
                 at Infragistics.Windows.Themes.DataPresenterResourceSet`1.get_CellValuePresenter()
            InnerException:
The thread with the exception's call stack is:
  PresentationFramework.dll!System.Windows.Markup.WpfXamlLoader.Load(System.Xaml.XamlReader xamlReader, System.Xaml.IXamlObjectWriterFactory writerFactory, bool skipJournaledProperties, object rootObject, System.Xaml.XamlObjectWriterSettings settings, System.Uri baseUri) + 0x170 bytes
  PresentationFramework.dll!System.Windows.Markup.WpfXamlLoader.LoadDeferredContent(System.Xaml.XamlReader xamlReader, System.Xaml.IXamlObjectWriterFactory writerFactory, bool skipJournaledProperties, object rootObject, System.Xaml.XamlObjectWriterSettings parentSettings, System.Uri baseUri) + 0x28 bytes
  PresentationFramework.dll!System.Windows.ResourceDictionary.CreateObject(System.Windows.Baml2006.KeyRecord key) + 0xc8 bytes
  PresentationFramework.dll!System.Windows.ResourceDictionary.OnGettingValue(object key, ref object value, out bool canCache) + 0x7f bytes
  PresentationFramework.dll!System.Windows.ResourceDictionary.OnGettingValuePrivate(object key, ref object value, out bool canCache) + 0x1d bytes
  PresentationFramework.dll!System.Windows.ResourceDictionary.GetValueWithoutLock(object key, out bool canCache) + 0x94 bytes
  PresentationFramework.dll!System.Windows.ResourceDictionary.GetValue(object key, out bool canCache) + 0x8b bytes
  PresentationFramework.dll!System.Windows.ResourceDictionary.GetValueWithoutLock(object key, out bool canCache) + 0x76 bytes
  PresentationFramework.dll!System.Windows.ResourceDictionary.FetchResource(object resourceKey, bool allowDeferredResourceReference, bool mustReturnDeferredResourceReference, bool canCacheAsThemeResource, out bool canCache) + 0x84 bytes
  PresentationFramework.dll!System.Windows.SystemResources.LookupResourceInDictionary(System.Windows.ResourceDictionary dictionary, object key, bool allowDeferredResourceReference, bool mustReturnDeferredResourceReference, out bool canCache) + 0x43 bytes
  PresentationFramework.dll!System.Windows.SystemResources.FindDictionaryResource(object key, System.Type typeKey, System.Windows.ResourceKey resourceKey, bool isTraceEnabled, bool allowDeferredResourceReference, bool mustReturnDeferredResourceReference, out bool canCache) + 0x7b bytes
  PresentationFramework.dll!System.Windows.SystemResources.FindResourceInternal(object key, bool allowDeferredResourceReference, bool mustReturnDeferredResourceReference) + 0x22e bytes
  PresentationFramework.dll!System.Windows.StyleHelper.GetThemeStyle(System.Windows.FrameworkElement fe, System.Windows.FrameworkContentElement fce) + 0x1ef bytes
  PresentationFramework.dll!System.Windows.FrameworkElement.UpdateThemeStyleProperty() + 0x45 bytes
  PresentationFramework.dll!System.Windows.FrameworkElement.OnInitialized(System.EventArgs e) + 0x2f bytes
  PresentationFramework.dll!System.Windows.FrameworkElement.TryFireInitialized() + 0x4e bytes
  PresentationFramework.dll!System.Windows.FrameworkElement.ChangeLogicalParent(System.Windows.DependencyObject newParent) + 0xaf bytes
  PresentationFramework.dll!System.Windows.FrameworkElement.AddLogicalChild(object child) + 0x6a bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.CellPlaceholder.CreateCachedElement(bool cacheInTemplateRecord) + 0x1d2 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.CellPlaceholder.VerifyCachedElement() + 0x111 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.CellPlaceholder.OnInitialized(System.EventArgs e) + 0x22 bytes
  PresentationFramework.dll!System.Windows.FrameworkElement.EndInit() + 0x23 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.AddPlaceholder(System.Windows.Controls.Panel placeholderPanel, Infragistics.Windows.DataPresenter.Field field, bool isLabel) + 0x110 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.InitializeCellPanel(System.Windows.Controls.Panel placeholderPanel, bool isLabelPanel) + 0xa8 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.InitializeCachedCellArea() + 0x5b0 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.VerifyCache() + 0x2c bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.NonVirtualizedCellFields.get() + 0x1d bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.VerifyFieldLists() + 0x1e4 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.MeasureOverride(System.Windows.Size availableSize) + 0x12a bytes
  PresentationFramework.dll!System.Windows.FrameworkElement.MeasureCore(System.Windows.Size availableSize) + 0x1cc bytes
  PresentationCore.dll!System.Windows.UIElement.Measure(System.Windows.Size availableSize) + 0x1cc bytes
  PresentationFramework.dll!MS.Internal.Helper.MeasureElementWithSingleChild(System.Windows.UIElement element, System.Windows.Size constraint) + 0x45 bytes
  PresentationFramework.dll!System.Windows.Controls.ContentPresenter.MeasureOverride(System.Windows.Size constraint) + 0x18 bytes
  InfragisticsWPF4.v13.1.dll!Infragistics.Windows.Controls.CardPanel.MeasureOverride(System.Windows.Size availableSize) + 0xda bytes
  PresentationFramework.dll!System.Windows.Controls.Control.MeasureOverride(System.Windows.Size constraint) + 0x60 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.DataRecordCellArea.MeasureOverride(System.Windows.Size availableSize) + 0x4f bytes
  PresentationFramework.dll!System.Windows.Controls.Grid.MeasureCell(int cell, bool forceInfinityV) + 0xe9 bytes
  PresentationFramework.dll!System.Windows.Controls.Grid.MeasureCellsGroup(int cellsHead, System.Windows.Size referenceSize, bool ignoreDesiredSizeU, bool forceInfinityV, out bool hasDesiredSizeUChanged) + 0x8a bytes
  PresentationFramework.dll!System.Windows.Controls.Grid.MeasureOverride(System.Windows.Size constraint) + 0x3e6 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.RecordPresenter.MeasureOverride(System.Windows.Size availableSize) + 0xaa8 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateNextElement(bool isHeader) + 0x123f bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateScrollableRecords() + 0x2d9 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateAllRecords() + 0x9a bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.GridViewPanelFlat.MeasureOverride(System.Windows.Size availableSize) + 0x984 bytes
  PresentationCore.dll!System.Windows.ContextLayoutManager.UpdateLayout() + 0x1a1 bytes
  PresentationCore.dll!System.Windows.ContextLayoutManager.UpdateLayoutCallback(object arg) + 0x19 bytes
  PresentationCore.dll!System.Windows.Media.MediaContext.InvokeOnRenderCallback.DoWork() + 0x10 bytes
  PresentationCore.dll!System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks() + 0x70 bytes
  PresentationCore.dll!System.Windows.Media.MediaContext.RenderMessageHandlerCore(object resizedCompositionTarget) + 0x82 bytes
  PresentationCore.dll!System.Windows.Media.MediaContext.RenderMessageHandler(object resizedCompositionTarget) + 0x2c bytes
  WindowsBase.dll!System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate callback, object args, int numArgs) + 0x52 bytes
  WindowsBase.dll!MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(object source, System.Delegate method, object args, int numArgs, System.Delegate catchHandler) + 0x3a bytes
  WindowsBase.dll!System.Windows.Threading.DispatcherOperation.InvokeImpl() + 0xac bytes
  WindowsBase.dll!System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(object state) + 0x38 bytes
  mscorlib.dll!System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx) Line 581 + 0xd bytes C#
  mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx) Line 530 + 0xd bytes C#
  mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state) Line 519 + 0xe bytes C#
  WindowsBase.dll!System.Windows.Threading.DispatcherOperation.Invoke() + 0x5b bytes
  WindowsBase.dll!System.Windows.Threading.Dispatcher.ProcessQueue() + 0x16b bytes
  WindowsBase.dll!System.Windows.Threading.Dispatcher.WndProcHook(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled) + 0x5a bytes
  WindowsBase.dll!MS.Win32.HwndWrapper.WndProc(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled) + 0x9b bytes
  WindowsBase.dll!MS.Win32.HwndSubclass.DispatcherCallbackOperation(object o) + 0x6b bytes
  WindowsBase.dll!System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority priority, System.TimeSpan timeout, System.Delegate method, object args, int numArgs) + 0x10e bytes
  WindowsBase.dll!MS.Win32.HwndSubclass.SubclassWndProc(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam) + 0xf1 bytes
  [Native to Managed Transition]
  [Managed to Native Transition]
  WindowsBase.dll!System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame frame) + 0xb1 bytes
  WindowsBase.dll!System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame frame) + 0x49 bytes
  WindowsBase.dll!System.Windows.Threading.Dispatcher.Run() + 0x4b bytes
> Zetta.exe!RCS.ZettaUI.ControlHost.BuildWindowCore.AnonymousMethod__0() Line 334 + 0x5 bytes C#
  mscorlib.dll!System.Threading.ThreadHelper.ThreadStart_Context(object state) Line 68 + 0x27 bytes C#
  mscorlib.dll!System.Threading.ThreadHelper.ThreadStart() Line 105 + 0x20 bytes C#
The second thread's call stack is:
  PresentationFramework.dll!System.Windows.FrameworkElement.FindResourceInTree(System.Windows.FrameworkElement feStart, System.Windows.FrameworkContentElement fceStart, System.Windows.DependencyProperty dp, object resourceKey, object unlinkedParent, bool allowDeferredResourceReference, bool mustReturnDeferredResourceReference, System.Windows.DependencyObject boundaryElement, out System.Windows.InheritanceBehavior inheritanceBehavior, out object source) + 0xff bytes
  PresentationFramework.dll!System.Windows.FrameworkElement.FindResourceInternal(System.Windows.FrameworkElement fe, System.Windows.FrameworkContentElement fce, System.Windows.DependencyProperty dp, object resourceKey, object unlinkedParent, bool allowDeferredResourceReference, bool mustReturnDeferredResourceReference, System.Windows.DependencyObject boundaryElement, bool isImplicitStyleLookup, out object source) + 0x7a bytes
  PresentationFramework.dll!System.Windows.FrameworkElement.FindImplicitStyleResource(System.Windows.FrameworkElement fe, object resourceKey, out object source) + 0x6c bytes
  PresentationFramework.dll!System.Windows.FrameworkElement.GetRawValue(System.Windows.DependencyProperty dp, System.Windows.PropertyMetadata metadata, ref System.Windows.EffectiveValueEntry entry) + 0xbe bytes
  PresentationFramework.dll!System.Windows.FrameworkElement.EvaluateBaseValueCore(System.Windows.DependencyProperty dp, System.Windows.PropertyMetadata metadata, ref System.Windows.EffectiveValueEntry newEntry) + 0x32 bytes
  WindowsBase.dll!System.Windows.DependencyObject.EvaluateEffectiveValue(System.Windows.EntryIndex entryIndex, System.Windows.DependencyProperty dp, System.Windows.PropertyMetadata metadata, System.Windows.EffectiveValueEntry oldEntry, System.Windows.EffectiveValueEntry newEntry, System.Windows.OperationType operationType) + 0x102 bytes
  WindowsBase.dll!System.Windows.DependencyObject.UpdateEffectiveValue(System.Windows.EntryIndex entryIndex, System.Windows.DependencyProperty dp, System.Windows.PropertyMetadata metadata, System.Windows.EffectiveValueEntry oldEntry, ref System.Windows.EffectiveValueEntry newEntry, bool coerceWithDeferredReference, bool coerceWithCurrentValue, System.Windows.OperationType operationType) + 0x379 bytes
  WindowsBase.dll!System.Windows.DependencyObject.InvalidateProperty(System.Windows.DependencyProperty dp, bool preserveCurrentValue) + 0xd1 bytes
  PresentationFramework.dll!System.Windows.FrameworkElement.UpdateStyleProperty() + 0x63 bytes
  PresentationFramework.dll!System.Windows.FrameworkElement.OnInitialized(System.EventArgs e) + 0x1c bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.InitializeCachedCellArea() + 0x4f0 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.NonVirtualizedLabelFields.get() + 0x1d bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.VerifyFieldLists() + 0x171 bytes
  PresentationFramework.dll!System.Windows.Controls.Grid.MeasureOverride(System.Windows.Size constraint) + 0x281 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateNextElement(bool isHeader) + 0x1271 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateHeader(Infragistics.Windows.DataPresenter.FieldLayout fl, Infragistics.Windows.DataPresenter.Record attachedToRecord) + 0x148 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateTopFixedRecords() + 0xf7 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateAllRecords() + 0x68 bytes
  PresentationFramework.dll!System.Windows.Controls.ItemsPresenter.MeasureOverride(System.Windows.Size constraint) + 0x18 bytes
  PresentationFramework.dll!System.Windows.Controls.ScrollContentPresenter.MeasureOverride(System.Windows.Size constraint) + 0x95 bytes
  PresentationFramework.dll!System.Windows.Controls.Grid.MeasureCellsGroup(int cellsHead, System.Windows.Size referenceSize, bool ignoreDesiredSizeU, bool forceInfinityV) + 0x2a bytes
  PresentationFramework.dll!System.Windows.Controls.Grid.MeasureOverride(System.Windows.Size constraint) + 0x1cb bytes
  PresentationFramework.dll!System.Windows.Controls.ScrollViewer.MeasureOverride(System.Windows.Size constraint) + 0x196 bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.RecordListControl.MeasureOverride(System.Windows.Size availableSize) + 0x4f bytes
  PresentationFramework.dll!System.Windows.Controls.Border.MeasureOverride(System.Windows.Size constraint) + 0x12f bytes
  InfragisticsWPF4.DataPresenter.v13.1.dll!Infragistics.Windows.DataPresenter.DataPresenterBase.MeasureOverride(System.Windows.Size constraint) + 0xaf bytes
  PresentationFramework.dll!System.Windows.Documents.AdornerDecorator.MeasureOverride(System.Windows.Size constraint) + 0x4d bytes
  InfragisticsWPF4.DockManager.v13.1.dll!Infragistics.Windows.DockManager.SplitPane.MeasureOverride(System.Windows.Size availableSize) + 0x76d bytes
  InfragisticsWPF4.DockManager.v13.1.dll!Infragistics.Windows.DockManager.DockManagerPanel.MeasureOverride(System.Windows.Size availableSize) + 0xbb9 bytes
The exception appears to be timing sensitive since it happens sporadically.  We first started experiencing the exception when we upgraded to V13.1.
Any ideas on why it is happening, and how it can be fixed?
Dan
  • 138253
    Hello Dan,
  • 138253
    Hello Dan,
    Thank you for your post. I have been looking into it and since this is not a known issue, could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
