Hi
I saw how to mark holidays on the calendar using the this link "http://ko.infragistics.com/community/forums/t/74325.aspx"
I have another requirement on top of this. I would like to display a tool tip when users hover over the days marked as holiday in the calendar. The challenge here is that I have a List<IHolidays> object in the view model. IHolidays interface has two properties DATE and DESCRIPTION. This is the collection I iterate over to mark the disabled dates. Now, how do I use this to bring the tool tip as well.
Chev
Thank you for your feedback Ranjith.
I am glad this approach helped you and I believe that it will be useful for other community members as well.
Thanks much. We can close this issue.
I am just checking your progress on the issue.
If you have any other questions regarding the CalendarDay styling, please feel free to ask.
There is a MultiTrigger in the “CalendarItemInner” ControlTemplate that is hit when the user hovers a day. It applies custom color for that date. In order to disable this functionality you could retemplate the default template defined in the eitors.generic.xaml file at C:\Program Files (x86)\Infragistics\2013.2\WPF\DefaultStyles\Editors and remove the trigger. I have modified the sample project to show this approach. Please feel free to ask if you have any questions.
Just one more question. Like you have a setter for the tooltip property I also created one for the background property and I set the color based on if the date is a holiday or not. All works perfectly.
Now when I take my cursor over the date which is a holiday the tooltip appears but the color disappears. Any idea why and how this could be solved?
