I have a XamDataGrid which is Bound to DataView as i dont know the fields (Its Dynamic)
but i want XamDataGrid to format Fields depend on their DataType ( Which Is also MYCustomdataType) & Formatting is also user Customizable LikE
MYCustomdataType1 which is a double internally but User can opt to show this value in many Diff Formats:-
10000 to (10,000) or -10-, I have a Class/service which handle this for me.
So if a Column of a dataview is of MyCustomDataType. it should get formatted as per the Object/Service Setting in GUI Only As i also Have Export To CSV feature So I cannot manipulate Actual Object Values at View Model before Binding it to Grid.
I tried the same via Changing Filed Class property:-
under FieldLayoutInitialized event
If(Field.DataType== typeof(MyCustomDataType))
Field.ConverterParameter = GetFormatStringFor(typeof(MyCustomDataType));Field.Converter = new FormattingConverter();
Its not working for me. Can you please help..
Hello shahanshah,
Thank you for your post. I have been looking into it and I can suggest you create a Style for the CellValuePresenter and use Triggers in order to apply different formats or use StyleSelector for the CellValuePresenter’s ContentTemplateSelector. Here:
http://ko.infragistics.com/community/forums/p/12559/421600.aspx
similar approaches are discussed. Please let me know if this helps you or you have further questions on this matter.
