580
Xamdatagrid field allow only decimal values
I Created the xamdatagird in my case the column are not static it’s dynamically generated in that how can I set all cell are allowed only decimal value I am using MVVM approach it’s there is any way to set that in the View design page itself I saw few post in infragistics there they are directly mentioning the Filed value for example
<igDP:Field Name="pct" Label="Passing %">
<igDP:Field.Settings>
<igDP:FieldSettings EditAsType="{x:Type sys:Double}" />
</igDP:Field.Settings>
</igDP:Field>
 In my case it’s not possible because the fields are generated dynamically how I can get this ,I attached the sample project also
XamDataGridSampel.rar
