Subject says it all. Before I spend too much time, is this even remotely possible?
Hello Sjoerd,
Thank you for your post. I have been looking into it and I can say that one instance of FlatDataSource can generate one cube at a time from a the set ItemsSource. If you want to have multiple cubes you should either reset the Cube Property of the FlatDataSource instance or have two instances bound to one Source with different Cubes. Please let me know if this helps you or you have further questions on this matter.
