590
XamDataGrid Field Converter with ConverterParameter
I'm having a problem using a converter on Fields in the XamDataGrid that works when I use an UnboundField. I have an integer value that I want to display leading zeros if the value is less than 10. i.e. value 1 should show up as 01
I'm including the source for a small example that shows the UnboundField working and the Field not working.
Here's my xaml:
<Window x:Class="WpfApplication1.MainWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:local="clr-namespace:WpfApplication1"
        xmlns:igDP="http://infragistics.com/DataPresenter"
        DataContext="{Binding RelativeSource={RelativeSource Self}}" >
    <Grid>
        <Grid.Resources>
            <local:StringFormatConverter x:Key="StringFormatConverter"/>
        </Grid.Resources>
        <igDP:XamDataGrid DataSource="{Binding Path=MyRecords}" >
            <igDP:XamDataGrid.FieldLayouts>
                <igDP:FieldLayout>
                    <igDP:FieldLayout.Fields>
                        <igDP:Field Name="ID" Converter="{StaticResource StringFormatConverter}" ConverterParameter="{}{0:00}" />
                        <igDP:UnboundField Label="ID-Unbound" BindingPath="ID" Converter="{StaticResource StringFormatConverter}" ConverterParameter="{}{0:00}" />
                        <igDP:Field Name="Name" />
                    </igDP:FieldLayout.Fields>
                </igDP:FieldLayout>
            </igDP:XamDataGrid.FieldLayouts>
        </igDP:XamDataGrid>
    </Grid>
</Window>
And here's my code behind.
using System;
using System.Collections.Generic;
using System.Globalization;
using System.Windows;
using System.Windows.Data;
namespace WpfApplication1
    public partial class MainWindow : Window
        public class MyRecord
            public int ID { getset; }
            public string Name { getset; }
            public MyRecord(int id, string name)
                ID = id;
                Name = name;
        public List<MyRecord> MyRecords { getset; }
        public MainWindow()
            MyRecords = new List<MyRecord>();
            MyRecords.Add(new MyRecord(0, "Bob"));
            MyRecords.Add(new MyRecord(0, "Frank"));
            MyRecords.Add(new MyRecord(1, "John"));
            MyRecords.Add(new MyRecord(10, "Mary"));
            InitializeComponent();
    public class StringFormatConverter : IValueConverter
        public object Convert(object value, Type targetType, object parameter, CultureInfo culture)
            return string.Format(parameter.ToString(), value);
        public object ConvertBack(object value, Type targetType, object parameter, CultureInfo culture)
            return value;
Any ideas?
  • 135
    Thank you for verifying the thread as answered, it will help other users may take better advantage of it.
    I am just checking if the latest reply helped you out and if you require any further assistance on the matter.
  • 135
    Verified Answer
    Thank you for your patience and cooperation on this case.
    I have further research on this case and found that since the converter is changing the value to a string type, you should set the EditAsType to string in the Field setting in order for the value to display with the leading zero:
    <igDP:Field Name="ID" Converter="{StaticResource StringFormatConverter}" ConverterParameter="{}{0:00}" >
                                <igDP:Field.Settings>
                                    <igDP:FieldSettings EditAsType="sys:String"/>
                                </igDP:Field.Settings>
                            </igDP:Field>
    Also, please note if the field is editable, the ConvertBack function of the Converter should also be modified to return the correct type for the underlying property.
    I have attached an isolated sample application for your reference. Please test this and let me know incase if you have any issue as it is working fine. Thank you.
    BaseDataGrid.zip
  • 135
    We received your support request concerning “XamDataGrid Field Converter with ConverterParameter.”and this case has been assigned to me. Infragistics is dedicated to helping you solve this issue. I am working on this case and I will update the case after my finding on this. Thank you.
    Sincerely,
    Chandradeep,
    Developer Support Engineer, MCTS
    www.infragistics.com/support
