720
Access xamgrid instance in xamgrid contextmenu
Hi
I have a xamgrid within which I have a xamgrid.contextmenu. I also have the below command class.
Command class
public class CopyToClipboardCommand : Freezable, ICommand
public static readonly DependencyProperty DataGridProperty =
DependencyProperty.Register("DataGrid", typeof (XamGrid),
typeof (CopyToClipboardCommand)
public XamGrid DataGrid
get { return (XamGrid)GetValue(DataGridProperty); }
set { SetValue(DataGridProperty, value); }
protected virtual void RaiseCanExecuteChanged()
if (CanExecuteChanged != null)
CanExecuteChanged(this, EventArgs.Empty);
#region ICommand
public bool CanExecute(object parameter)
return true;
public event EventHandler CanExecuteChanged;
public void Execute(object parameter)
DataGrid.CopyToClipboard();
#endregion
protected override Freezable CreateInstanceCore()
return new CopyToClipboardCommand();
I bind the above class to one of the menu item as shown below
// Bindings not shown for clarity
<ig:XamGrid x:Name="grid">
<ig:XamGrid.ContextMenu>
<ContextMenu>
<MenuItem Header="Copy">
<MenuItem.Command>
<commands:CopyToClipboardCommand
DataGrid="{Binding ElementName=grid}"/>
</MenuItem.Command>
</MenuItem>
</ContextMenu>
</ig:XamGrid.ContextMenu>
</ig:XamGrid>
The grid instance is always passed as null to the Execute and the CanExecute methods. I guess somehow the context menu is not able to access the xamgrid instance even though I use binding elementName=grid. Can you let me know what is going wrong here that I'm not able to access the xamgrid instance inside my command class?
Chev
  • 34810
    Verified Answer
    Hello Ranjith,
    The reason for this issue is that the ContextMenu is not in the same visual tree as the XamGrid.
    As a solution, you can use a binding similar to the following:
    <ContextMenu DataContext="{Binding PlacementTarget, RelativeSource={RelativeSource Self}}">
                            <MenuItem.Command>
                                <commands:CopyToClipboardCommand DataGrid="{Binding}"/>
                            </MenuItem.Command>
                        </MenuItem>
                    </ContextMenu>
    Please reach out to me if you have any other questions or concerns.
    Sincerely,
    Andrew
    Developer Support I
    Infragistics.Inc
    www.infragistics.com/support
