625
XamDataGrid - System.OverflowException: Negating the minimum value of a twos complement number is invalid.
I am getting a strange error occurring intermittently with a xamDataGrid in WPF. The stack trace is as follows. Please advise as to what may be causing this issue. I presume it is something to with the scroll manager inside the xamDataGrid?
   at System.Math.AbsHelper(Int32 value)
   at Infragistics.Windows.Selection.SelectionStrategyBase.AutoScrollManager.Initialize()
   at Infragistics.Windows.Selection.SelectionStrategyBase.AutoScrollManager..ctor(SelectionStrategyBase selectionStrategy, AutoScrollInfo autoScrollInfo, MouseEventArgs mouseEventArgs, Boolean directionIsVertical)
   at Infragistics.Windows.Selection.SelectionStrategyBase.ManageTimers(MouseEventArgs mouseEventArgs)
   at Infragistics.Windows.Selection.SelectionStrategySingle.OnMouseMove(ISelectableItem item, MouseEventArgs e)
   at Infragistics.Windows.Selection.SelectionController.OnMouseMove(MouseEventArgs e)
   at Infragistics.Windows.Controls.IGControlBase.OnMouseMove(MouseEventArgs e)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.OnMouseMove(MouseEventArgs e)
   at System.Windows.UIElement.OnMouseMoveThunk(Object sender, MouseEventArgs e)
   at System.Windows.Input.MouseEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
   at System.Windows.Input.MouseDevice.Synchronize()
   at System.Windows.Input.MouseDevice.OnHitTestInvalidatedAsync(Object sender, EventArgs e)
   at System.Windows.Input.InputManager.HitTestInvalidatedAsyncCallback(Object arg)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
The XAML is fairly straightforward databound grid:
<igWPF:XamDataGrid Grid.Row="1" x:Name="XamDataGrid" Background="Transparent" GroupByAreaLocation="None" SelectedItemsChanged="XamDataGrid_SelectedItemsChanged">
<igWPF:XamDataGrid.FieldSettings>
<igWPF:FieldSettings AllowEdit="False" CellClickAction="SelectRecord" AllowRecordFiltering="True" FilterOperatorDefaultValue="Contains"/>
</igWPF:XamDataGrid.FieldSettings>
<igWPF:XamDataGrid.FieldLayouts>
<igWPF:FieldLayout>
<igWPF:FieldLayout.Settings>
<igWPF:FieldLayoutSettings AllowAddNew="False" AllowDelete="False" AutoGenerateFields="False" RecordSelectorLocation="None" LabelLocation="Hidden" SelectionTypeRecord="Single" FilterUIType="Default"/>
</igWPF:FieldLayout.Settings>
<igWPF:UnboundField Name="FieldA" BindingPath="FieldA" Label="" Width="Auto"/>
<igWPF:UnboundField BindingPath="FieldB" Label="" Width="*" IsScrollTipField="True">
<igWPF:Field.Settings>
<igWPF:FieldSettings>
<igWPF:FieldSettings.EditorStyle>
<Style TargetType="{x:Type igWPF:XamTextEditor}" BasedOn="{StaticResource {x:Type igWPF:XamTextEditor}}">
<Setter Property="TextWrapping" Value="Wrap"></Setter>
</Style>
</igWPF:FieldSettings.EditorStyle>
</igWPF:FieldSettings>
</igWPF:Field.Settings>
</igWPF:UnboundField>
</igWPF:FieldLayout>
</igWPF:XamDataGrid.FieldLayouts>
</igWPF:XamDataGrid>
