sorry not good at WPF yet... If I set autoGenerate on I get the heading and data displayed for all the rows. If I set it off the rows appear to be there. But nothing shows up for heading or data. What is the magic of getting the fields linked up? thanks
on the code side:
MyDataBase mydb = new MyDataBase(); var ds = (from x in mydb.vwCompanyProcessingInfoData select x).ToList(); BindingList<vwCompanyProcessingInfo> bindingList = new BindingList<vwCompanyProcessingInfo>(ds); dataGrid.DataSource = bindingList;
on the xaml side:
<Grid x:Name="LayoutRoot" Width="Auto"> <!--#BEGIN SNIPPET#--> <igDP:XamDataGrid x:Name="dataGrid" Grid.Row="0" GroupByAreaLocation="None" DataSource="{Binding vwCompanyProcessingInfo}">
<igDP:XamDataGrid.FieldLayoutSettings> <igDP:FieldLayoutSettings AutoGenerateFields="false"/> </igDP:XamDataGrid.FieldLayoutSettings> <igDP:XamDataGrid.FieldSettings> <igDP:FieldSettings LabelClickAction="Nothing" AllowEdit="False" AllowGroupBy="false" AllowRecordFiltering="True" /> </igDP:XamDataGrid.FieldSettings> <igDP:XamDataGrid.FieldLayouts> <igDP:FieldLayout> <igDP:FieldLayout.Fields> <igDP:Field Name="CompanyName" Label="Company Name" Visibility="Visible" /> <igDP:Field Name="isTechMultiBill" Visibility="Visible" /> <igDP:Field Name="isFieldInspectionMultiBill" /> <igDP:Field Name="isTechTestMultiBillSpecial" /> <igDP:Field Name="isFieldInspectionMultiBillSpecial" /> <igDP:Field Name="FieldInspectionApprover_or_PO" /> <igDP:Field Name="TechTestApprover_or_PO" /> <igDP:Field Name="isTechTestSignatureRequired" /> <igDP:Field Name="isFieldInspectionSignatureRequired" /> <igDP:Field Name="isMustHaveTechTestPOorAPR" /> <igDP:Field Name="isMustHaveFieldInspectionPOorAPR" /> <igDP:Field Name="LastUpdateUserID" /> <igDP:Field Name="LastUpdateDateTime" /> </igDP:FieldLayout.Fields> </igDP:FieldLayout> </igDP:XamDataGrid.FieldLayouts> </igDP:XamDataGrid> <!--#END SNIPPET#-->
</Grid>
Hello Paul,
Thanks again.
OK - never mind apparently if you screw up a fieldname then it doesn't work at all. one field was misspelled.
