1410
DataPresenterCommands.CellNext doesn't work
We are using Infragistics WPF 13.2.20132.2036. (XamDataGrid)
The goal is, that when user edit a value inside the grid and hit enter, the focus should go immediately to the next cell.
This works fine if only there are multiple columns in the grid.
If I have only one column - it stops work when user reaches"new row" record.
Can you pls help me out.. I cannot see what I'm doing wrong here.
In the attachment you will find: a very simple demo application and two videos explaining in a straightforward way what I'm trying to achieve.
This looks as a bug at first glance.
Desktop.rar
  • 138253
    Verified Answer
    Hello Lukasz,
    Thank you for your post. I have been looking into it and the sample you have attached and I modified it, so now it works as you want. Basically in the handled for the EditModeEnded event I added a check if the ActiveCell’s Record is AddNewRecord and if so I execute the XamDataGrid’s RecordManager’s CommitAddRecord method in order to add the new record. Please let me know if this helps you or you have further questions on this matter.
    XamDataGridEnterAppModified.zip
