Hi, I have a problem with changing the background color. I have used the http://ko.infragistics.com/community/forums/t/84972.aspx site help and it is working for the Pie and Doughnut charts but for the funnel is not working.
Can you help me?
Hi Andrew, thank you for the response and the sample, the functionality it is working, for all kind of chart controls (Pie chart, Doughnut chart, Funnel chart).
Hello Michael,
One option to color the individual slices is to set the Brushes property on the FunnelChart.
To do this, I created a BrushCollection and added 5 colors to it. Then I set FunnelChart1.Brushes = MyBrushCollection. Keep in mind that the color at the index of the brush collection will be proportionate to the index of the data source that you are using. In other words, BrushCollection[1] will be the color of the funnel chart slice for FunnelChartDataSource[1].
I have attached the sample demonstrating the above.
Please let me know if you have any questions or concerns.
Sincerely,AndrewDeveloper Support IInfragistics Inc.www.infragistics.com/support
