280
Select different ItemTemplate in OrgChartNodeLayout depending on conditions
Hello all,
I need a scenario in which the item template of OrgChartNodeLayout(in GlobalNodeLayouts) needs to be different based on some conditions.
For example:
<ig:XamOrgChart.GlobalNodeLayouts>
<ig:OrgChartNodeLayout
TargetTypeName="Department"
DisplayMemberPath="DepartmentName"
Key="Departments"
</ig:XamOrgChart.GlobalNodeLayouts>
In above example, suppose if Department has sub-Departments, then, one template should be used.
But if that Department doesn't have Sub-Departments,instead ,has Employees, then other template should be used.
The class structure for Department class is :
public class Department
public Department(string name)
this.DepartmentName =name;
this.Departments = new ObservableCollection<Department>();
this.Employees = new ObservableCollection<Employee>();
public string DepartmentName { get; set; }
public ObservableCollection<Department> Departments { get; set; }
public ObservableCollection<Employee> Employees { get; set; }
If  Department has Sub-Departments, the Departments(Observable collection) will have value [Count > 1] and if it doesn't have Sub-Department, then the Employees will have value [Count > 1].
How can I achieve different Item Template based on above conditions? [For List Box , there is itemTemplateSelector, is there any similar approach in this one? ]
Thank you in advance for your time.
Help..
