I have the next problem. I want to indicate to the image the source of it depending some values of the record. In the first Converter (ConvFoto), i get the row, but i can't no modify the source of the image. However, in the second converter (ConvFotoDos), i can modify the source of the image, but i can not get the row source.
<igDP:UnboundField Label="Photo" Name="ImageUri" Converter="{StaticResource ConvFoto}"> <igDP:UnboundField.Settings> <igDP:FieldSettings AllowResize="False" CellWidth="30" LabelWidth="20" CellMaxHeight="20" > <igDP:FieldSettings.CellValuePresenterStyle > <Style TargetType="{x:Type igDP:CellValuePresenter}"> <Setter Property="Template"> <Setter.Value> <ControlTemplate> <Image Source="{Binding RelativeSource ={RelativeSource TemplatedParent},
Converter={StaticResource ConvFotoDos}}" > </Image> </ControlTemplate> </Setter.Value> </Setter> </Style> </igDP:FieldSettings.CellValuePresenterStyle> </igDP:FieldSettings> </igDP:UnboundField.Settings> </igDP:UnboundField>
What I have to do to in the second convert get the info of the row?
Hello Igor,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thank you for your post. I have been looking into it and I can suggest you use the second Converter with a little modification. You can use RelativeSource in order to get the row data. It could look like this:
<igDP:UnboundField Label="Photo" Name="ImageUri"> <igDP:UnboundField.Settings> <igDP:FieldSettings AllowResize="False" CellWidth="30" LabelWidth="20" CellMaxHeight="20" > <igDP:FieldSettings.CellValuePresenterStyle > <Style TargetType="{x:Type igDP:CellValuePresenter}"> <Setter Property="ContentTemplate"> <Setter.Value> <DataTemplate> <Image Source="{Binding RelativeSource={RelativeSource AncestorType={x:Type igDP:DataRecordPresenter}}, Path=DataRecord, Converter={StaticResource ConvFotoDos}}"> </Image> </DataTemplate> </Setter.Value> </Setter> </Style> </igDP:FieldSettings.CellValuePresenterStyle> </igDP:FieldSettings> </igDP:UnboundField.Settings> </igDP:UnboundField>
Please let me know if you need further clarifications on this matter.
