Hallo,
1. How can I change the display Text in xamComboEditor by multi selection ?
Example from test1,test2,test3 where test1,test2,test3 are selectedItems to
display test1/test2/test3 ('/' in place of ',').
The EmptyText property is just for the case where nothing is selected, i suppose there
is another property for displaying the Text but it is private ?
2. How can sort those elements ?
Example if someone selects first test3 then test2 and test1, the display text will be
test3,test2,test1, but i want them to be sorted test1,test2,test3.
3. What is the best way to bind to SelectedItems ? I know that the SelectedItems collection
changes when I select some object in the control, but how can I for example set the SelectedItems property
from my ViewModel ? I need this because I get the List of Objects from my Database and I need to set the SelectedItems from
my ViewModel ?
Thank you for your post. I have been looking into your questions and in order to replace the delimiter with another symbol you need to set the ‘MultiSelectValueDelimiter’ property of the XamComboEditor like e.g.:
MultiSelectValueDelimiter="/"
If you would like to sort the selected items in the XamComboEditor, you could handle the ‘SelectionChanged’ event of the XamComboEditor and sort the selected items using reflection like e.g.:
private void combo_SelectionChanged(object sender, Infragistics.Controls.Editors.SelectionChangedEventArgs e)
ObservableCollection<object> sortedSelectedItems = new ObservableCollection<object>(combo.SelectedItems.OrderBy(p => p.GetType().GetProperty(combo.DisplayMemberPath).GetValue(p, null)).ToList());
combo.SelectionChanged -= new EventHandler<Infragistics.Controls.Editors.SelectionChangedEventArgs>(combo_SelectionChanged);
combo.SelectedItems = sortedSelectedItems;
combo.SelectionChanged += new EventHandler<Infragistics.Controls.Editors.SelectionChangedEventArgs>(combo_SelectionChanged);
In order to bind the selected items to a collection from your ViewModel you need to define ObsevableCollection of objects and bind the ‘SelectedItems’ property to it.
I am attaching a sample application(ComboEditor_MultiSelection_Separator_Sort.zip) that shows all this functionalities.
Let me know, if you need any further assistance on this matter.
